Silly question, is your speedo electronic? Steve
Drill a hole in grease cap. Use the VW cap as guide for hole size (a small file can square the corners of hole)
If your spindle is drilled for a an abs sensor you can use the abs sensor by grounding one wire and running the other to the speedo. Did that for the race car and it works perfect.
sender
yes speedo is electric steve ,but I think these other members have sorted it
thanks for that
gee dub |
Does your speedo use a electronic conversion module from the stock bug speedo cable?
I was going that route, but I have something WAY OVER THE TOP now! (will show in a few months)
speedometer sender
Hi sorry for the delayed response,I have no module , at he moment I just have the electronic auto meter speedo ,I am planning on using the auto meter sender with that fitted to the front 944 spindle. I am assuming they make a cable to connect the two together .
gee dub |
speedometer sender
Hi Humble ,just looked at your post again re, the abs sender that sounds like a plan. Sorry for that I have just read that again today, I think I miss read that the other day,thanks for your help guys.
gee dub |
