Old January 31st 2003, 12:37
BigPhattyVW's Avatar
BigPhattyVW BigPhattyVW is offline
One engine question after another!!
Hello!!
What dimension of an engine, and when I mean dimension I mean stroke x bore, will I need cylinder spacers. What I would like to do is put a 76 or a 78 stroker in my engine but what size of pistons would require spacers. Do they make stroker pistons that eliminate the need for spacers? Oh well hopefully someone can answer at least one of my questions!!
Thanks for the answers!!
Clint
Coming Soon!
86mm X 90.5mm German Look Bad *** VW
Hopefully Soon!!
Back home in Port Orchard, and saving for the Bug
Old January 31st 2003, 15:53
Pillow's Avatar
Pillow Pillow is offline
For a T1 engine there are "B" piston and cylinder sets built for strokers. I think for a 82m crank, but are perfect for a conservative CR 78.4mm crank. The 76 is too far in the hole and would need the cyliders shaved down to get any CR out of it.
The normal 69mm P&Cs are refered to as "A" units.
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old January 31st 2003, 23:49
Tim Tim is offline
Another thing you may consider is the rod length. If you use longer rod than stock, probably you need spacers even for "B" p/c sets.
Tim
Old February 2nd 2003, 00:03
Pillow's Avatar
Very good point Tim. The above is only generalizations based off a VW rod... If you like Chevy rods it get exciting fast
Adrian Pillow
Old February 3rd 2003, 17:29
Yeah I'm going to use 5.5 inch race rods. Another inquery, yet again, is there a way to put a four point spark plugs into a vw head? I had another question but im really slow right now so I'll get back to you guys with the rest!
Clint
Coming Soon!
Hopefully Soon!!
