#31
Your doing excellent work, I'm taking the body off a 1303 soon so it can be painted, I'm glad that we don't have the same problems down here as you do there. I might be seeing things but in the photo http://www.keversite.nl/fotoalbum/fotos/99903.jpg it looks like there is some sort bulge on the chassis floor at the rear end behind the seat rails, is this for something special or is it a piece of your bug puzzle waiting to be fitted? Steve
#32
The bulge is made to fit the oilcooler, I think this will have plenty of airflow. Good luck with your car. ![]() Paul.
#33
Nice work Paul! I don´t think I have ever seen anyone make such a big modification for an oil cooler! I like it!
#34
This looks nice. No rear legroom, but who care!
1967 Bug |
#35
No rear seat, so who cares
#36
Wow I never would have thought of doing that. Steve
#37
nice work well done
kerb$ide ku$toms |
#38
Slick I like! Hmmmm
#39
Found some time to work on the car again 8)
The underside of the left doorpillar was bad, of course > ![]() time for a Hoekie of Hooky ![]() ![]() First I had to shorten it, this way the bracing could stay in it's place. ![]() fitting ![]() It only needs some welding. 8) ![]() Paul.
#40
This morning it was time to finish the doorpillar.
Welded the hooky piece. ![]() Normally you can not reach the inside, mine is still open and it is double sheetmetal so I also welded the inside. ![]() Then I dismantled the door (this is very heavy with all the parts and glass in it) and checked the gap, I must say ; I am very pleased with it. ![]() Paul.
#41
Awesome work Paul! keep update!!
#42
Thanks, I am ill wright now but next week it is time to do some work again.
Paul.
#43
Not much time lately, but still a Little progress.
This piece of the trunk was a little thin, also the holes didn't mach the new kick panel. so I replaced the top of the kick panel by a wider piece, this way I can close (weld) all the holes. ![]() ![]() And all the holes are closed again. before paint I will put some lead filler on it and it will be as new again, offcourse I will do the corners first. ![]() Paul.
#44
Paul where did you get the lower door post panel to buy.
#45
| Currently Active Users Viewing This Thread: 14 (0 members and 14 guests) | |
