Old January 5th 2011, 23:34
Yogie Yogie is offline
What front spindles do I need?
I have a 72 Karmann Ghia that I want to fit 944 brakes to on the front. I have the calipers from an '86 944 Turbo and some 17" twists from a Carrera already.
What I need to know is, what type of spindles will I need to buy to make this work and any other modifications that have to be done. I would like to be able to run the standard speedo cable through the hub as well.
I am doing the rears as well but I have found the info I need to make that work, it is just the front I am unsure about.
Thanks for any advice you can give me.
Yogie
Old January 6th 2011, 18:13
flat flat is offline
There's no bolt-on way. You have to modify the 944 hubs for beetle bearings so they fit the KG spindle. Or you can chop off a beetle drum to make a hub, then slip the 944 rotor over that. And ofcourse fabricate a caliper bracket.
www.vdubengineering.com
Old January 9th 2011, 05:50
Thanks Lanner. Do you make a kit with the 944 hubs already modified to fit the ghia disc brake spindle? If you do, is there a part number you can give me or a price or something?
Yogie
Old January 9th 2011, 14:09
brujo65 brujo65 is offline
his brake kit work very nice, I have it in my ghia
Old January 10th 2011, 01:13
Thanks Brujo65. Did the hub just go on to the standard ghia spindle or did you need to make a new one? Did you still need to buy a new caliper bracket as well?
Yogie
Old January 10th 2011, 02:17
I send Lanner my spindle + hubs and he did his magic
Old January 10th 2011, 03:47
Thanks.
Old January 10th 2011, 17:16
Yeah, you have to send me your 944 hubs and vw spindles. I'll machine the hub and fabricate the caliper bracket and modify the spindle to suit. $c340 for the work including new bearings/seals and all required hardware.
Cheers,
Old January 10th 2011, 17:32
Thanks Lanner.
Is it the early N/A hubs you need from the 944 or will any model do? I have the front 86 turbo calipers.
Yogie
Old January 13th 2011, 17:25
You need the turbo rotors, they came in two flavours:
a)86 (rear mount via 5 bolts)
b)87-89 (front mount, slip over hub)
The hubs have to match the rotors. The 87+ NA/T hubs are the same. All 4 piston brembo's on the 944/964s/Rear 993 are basically the same with minor changes in cosmetics and piston size. The mounting points are the same and the calipers interchangeable.
