#676
Good eye! It used to touch over a year ago, not not anymore. Damage was done and I don't mind too much tbh. There's also a little dent there from someone that ran into me in a traffic jam 2 years ago...
#677
http://www.youtube.com/watch?v=f4iuImkFo0I[/QUOTE]
Hay Walter, man nice work . Question, that G50 has tall gearing, in your video was that 4th to 5th gear? It looked and sounded like you could have continued to accelorate even more. Again damn nice results, congrats.
#678
4th gear and yes, that was a little over 6K, but it goes on to 7K and wants to go further then... Very curieus untill how far it continues to make power on the dyno.
#679
Congrats Wally! Looks and sounds great!
#680
looking good. be intresting to see the dyno results on this set up compered to the old one. are you going for more boost or was the swap to the bigger turbo to control the boost better?
#681
The other idea was to decrease exhaust gas back pressure by using an even bigger (compared to the already bigger compressor) turbine wheel. So, the turbine wheel now is double big so to speak... hence the to be expected huge lag. I think partly due to the twin-scroll set-up, lag is not as terrible as it would have been otherwise. OTOH, less back pressure will make higher boost settings possible. For example: 20 psi gave me 30psi back pressure(!). You can fill out what this means if you have a (assuming) 1:1 ratio... Question is will the engine internals withstand the mechanical forces (++torque) of more boost or even same boost but with more power because of the better VE I think I have now? I tried tuning it on the road, but frankfully, its too tricky on a public road at the boost settings above 15 psi. Tuning is not complete therefore, but close enough ![]() -only one way to find out: drag it to the dyno
#682
Dyno has been booked for coming saturday...
#683
It will keep on making power until the valve springs float.
Steve Arndt |
#684
Fantastic !
Based on your last "seat of the pants" comment, I'm guessing you'll be dynoing to 15 psi then ? Are you still using the ID1000's ? Looking forward to the results and the conclusion of your exhaust back pressure / turbine size testing. Sandeep |
#685
![]() If the engine will hold (knock on wood), I want to at least test 22 psi (1,5 bar) as well. It looks like this combo holds boost pretty constant across the rpm range. Quote:
#686
Unfortunately, no such luck today: injectors were at 100% IDC already at 1,3 bar boost and ~6500 rpm...
But 398 hp and climbing at 1.3 bar but running at lambda 1.0 and 1.1 at that power level... that probably did the engine no good, but no problems leaving the dyno...but I still did strand on the way back home. Seemed like electrical problems or fuel delivery problems or ? Not sure what it is yet though... This was the first run at 15 psi: http://www.youtube.com/watch?v=9TOIdkF6mbg
#687
You made almost 400 whp at 19lbs of boost. You were also lean, need to increase fuel at that level.
#688
IDC at 100% ? Injectors too small also? I figured 1000cc would be enough running pump gas at that horsepower level.Perhaps not enough fuel pressure for the amount of fuel volume needed? In other words rail pressure is dropping because the pump canīt keep up with the boost/fuel ratio and maintain the desired pressure and the injectors try to compensate with longer opening intervals? Itīs just a guess - Iīm not sure if that makes sense but I canīt imagine that the injectors are too small at that level?
Maybe itīs none of the above and you donīt have enough electrical power/current to support the pump? What I donīt understand is,youīve had a higher boostsetting,ran richer(?) and HP before the turbo change.So how is it possible that it suddenly collapses? |
#689
I have found the cause: my feed pump wasn't running well and I got stranded because it didn't run at that moment at all anymore!
Logical that when you have no fuel anymore, the engine dies out...duh! I had a spare 944 pump I switched over and it started cold immediately again :mrgreen: Pffft! I left the fuel pressure to 60 psi, so according to the flow sheet that should give me 1180 cc, which should be enough anyways. Just need to re-map the fuel map but thats no biggie. Very glad it was something this simple, but scary as it could have ended far worse. Amazingly and fortunately the engine held... |
#690
That's good to hear it was something simple and no damage caused!
| Currently Active Users Viewing This Thread: 38 (0 members and 38 guests) | |
