Old July 18th 2011, 07:36
evilC's Avatar
evilC evilC is offline
Originally Posted by KAZ909 View Post
Hi evil C,
Wondering what offset, brand, design etc 15" wheels you fitted that clear 944T calipers, or did you spacers with long studs.
I want to use 15" wheels as good rally tyres are only available in 15"
Thanks John
Hi John,
The wheels are 6" teledials (at the moment) and I added 30mm spacers that was as much to fill the arches as to clear the calipers. With those wheels it would need only small spacers ~5-10mm to clear shaved calipers and maybe none at all as the teledials have a very deep and thick well that causes the clearance issues.
The calipers were originally for a 16" wheel with the 299mm disc so since I was already committed to the wheels and the disc, I slotted the mounting holes, added crescent fillers and relieved the pads. All of that was more to fit the disc rather than anything else. I will when the pads have worn revert to the 299mm disc having now got the clearance c20mm between the caliper and the wheel that results from the spacers.
Whilst I agree with you that the gravel and forest stage tyres are mostly 15", the tarmac spec tyres are more useally found in the 16+" diameters especially if you are not to affect the gearing too much.
