Old October 8th 2011, 14:06
I finally had enough of the restricted steering, tyre rubbing and compromised steering geometry so found a set of wider front wings in conjunction with some concentric wheel spacers. I also plan to rebuild the steering rack with adjustable end stops to maximise the lock available. The wings will also need modifying to provide a better mounting surface for the air damn. From a quick drive around it is significantly better.. The front bumper brackets will need to be extended slightly to give a bit more space to the wings too but I think it will end up looking better with more flowing lines.
