Old December 10th 2011, 17:22
Today I started making the '58 parafan look like an '56.
Here is the difference between the '58 and '56.
Time to cut again.
Cutting, and trying.
The result of a few hours work.
Paul.
Old December 17th 2011, 16:51
Today I worked on the wipers again.
Just to be sure I mounted the mechanism and it fits. (sorry for the crappy phone pic's)
To mount the mechanism I had to weld this bracket as well
Paul.
Old December 24th 2011, 17:47
Not much....but it is progress.
all welded and smoothend, also welded the hole for the screen washer.
Paul.
Old December 29th 2011, 11:38
Wile the front is removeable, I have good access to drill the cage holes.
Never thought the hole would have this shape.
The cage can not hit the pedalbox, innerwing and fueltank, and has to end in the sparewheel well to be welded to the Porsche frontwheel mounts.
The cage will also run under the dash, this will fit perfect later on.
With this piece of cardboard the hole on the right will be easier.
Paul.
Old January 6th 2012, 17:31
Took the doors from the attic and dismantled them (they weigh a ton with all the windows etc.).
trail fitted the left door, fixated it with the wright gabs and made the first welds
When the right door is fixated and the pillar is tackwelded as well, I will start on the window surrounding.
Paul.
Old January 11th 2012, 16:44
And the right is getting there as well. Its not easy fitting a door in a shell that is not welded and bin appart completely
Paul.
Old January 11th 2012, 17:28
Stevo_L's Avatar
Stevo_L Stevo_L is offline
you doin´ really great work! i´m speechless!
german-ghia.blogspot.com
Old January 12th 2012, 16:30
I am trying Stevo. After reading this it all looks so simple, but I have lots of headaches and there is alot of swearing before the pictures are taken.
Paul.
Old January 13th 2012, 03:22
You are doing some mighty fine work there.
Old January 13th 2012, 07:26
Old January 21st 2012, 16:31
Time to restore the window corners, this is not easy cos this is where the '58 is different from the '56
First I had to cut some more of the '56, and then I started to make my own '58 - '56 puzzle.
The before picture.
Cut a piece of '58 in to the wright shape to follow the '56 windowl line.
I had some leftovers from the '56, they came in handy now.
after a lot of testfits, I am a happy man.
Paul
Old January 28th 2012, 16:24
The right is tacked as well, doesn't look like much but this took me several hours.
Paul.
Old January 29th 2012, 13:21
speedy's Avatar
speedy speedy is offline
A brilliant thread and inspiration to all of us
Jonathan
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old January 29th 2012, 14:10
Jonathan
Thanks Jonathan.
Old February 11th 2012, 16:21
If it has to be good, it has to be worse first. So the hole had to be bigger.
I used a piece from the '56, but is was pretty rotten at the vertical edge.
Made a new vertical piece (Real PITA) and welded it in. took me all morning but it's done.
Paul.
