#226
Due to the fact that I have to use X-joints (don't know what they're called) in the steering, the steering column had to have an extra bearing. So I made a bracket, shortend the column and mounted the bearing. I am pretty pleased with it.
![]() ![]() Paul.
#227
Looks good.
#228
#229
I didn't like the way the gearbox was hanging (i did this 2jrs ago) so it was time for "plan B".
"Plan B" is mounting the gearbox higher, further inwards and solid. ![]() ![]() Back mount are ready, now it is time to do the front. Paul.
#230
Getting closer to a roller!!!
#231
#232
Also made a solid mount for the clutch side.
![]() Paul
#233
Won these today on Evilbay, Spax Coilovers.
![]() Paul.
#234
I Wasn't happy with the first gearbox mount. So it was time for plan B. The new frame horns.
![]() ![]() Paul.
#235
The frame-horn replacements are ready, when the body goes of I will make the def. welds.
![]() I widened the gearbox mount, this will make it stronger and improve the looks of the roll cage. ![]() Paul.
#236
Also made a start on the cage today. I want to be able to use the backseat. this is my try of a rollcage with a backseat.
![]() ![]() Paul.
#237
Loving this build, keep the photos coming. I made this reply because sometimes when you post things and you don't get a reply it seems like your talking to yourself. I really like what you did with chassis forks. Steve
#238
Paul.
#239
Yes, I am lurching this thread, keep up the good work!
#240
Thanks Gerrelt, I will.
