Old September 7th 2013, 12:44
effvee effvee is offline
torsion bars
Hay, are you using torsion bars and coil over springs. I see many are using the 944 trailing arms, with coil over springs. Is there a reason why you choose not to remove the torsion bars, if you are using both. I know many are of the opinion that since the 911 use the torsion bars that's the hot ticket. However the sway bars, coil over springs application should work equally well if not better.
