Old September 15th 2016, 15:31
effvee effvee is offline
engine plus heads
Hi, anyone know what the cc are on the engine plus heads.
Old September 16th 2016, 01:27
Not exactly, but why is this so important? Anything can be made bigger or smaller right?
Stock its pretty large (65cc or more iirc) as they are meant for 103-105 bore (stroker) engines with the resulting bigger then usual capacity.
Old September 16th 2016, 04:08
I need to start having the cylinders cut, I want zero deck height. I will be going for 8 compression
Old September 16th 2016, 05:33
Just do it! Actual measuring of the heads themselves (the ones YOU will use) is always neccessary to set the exact CR you want though.
On a high end engine you cannot use generic values, but thats obvious right ;-)
Old September 21st 2016, 05:46
50 intake 41exhaust
I now have measurements that I can set thing in motion. I have been jogging between wanting a EZ-36D, only if I could have installed it under the deck lid. I don't see where it possible. So, I am having my cylinder shortened in height by .125. I went to CB's site and used their calculator. Everyone says to keep static compression around 7. However I also have heard that at 7, the engine can be gutless. Even though my I had my cylinders made, I chose I believe 6075, with a heat treatment.
I need to have these cylinders cryo treated and Nikisil treated. Given that I tried to add as many fins and lower my fan pulley ratio, I hope the 8 compression will hold up under one atmosphere of boost. I unless I here more on the 3.6 Subaru, I'm back on my 3 liter type IV.
