Old August 5th 2018, 18:52
DORIGTT's Avatar
DORIGTT DORIGTT is offline
HELP w/944T-IRS a-arm swap
Hey all,
I've got a 1970 IRS pan and am trying to convert to the 944T arms and spring plates. Challenge is, I'm having trouble getting the spring plate to sit on the spring plate. Has anyone else run into this?
Old August 6th 2018, 14:52
Blizzard's Avatar
Blizzard Blizzard is offline
Is the original rubber still on the inner side of the 944 spring plate? If so remove this rubber and replace it with one for a beetle.
Old August 6th 2018, 15:14
Blizzard's Avatar
Old August 13th 2018, 21:25
DORIGTT's Avatar
I have removed both the inner and outer rubbers and replaced them with the Volkswagen ones as I don't have the Porsche covers for the torsion housings.
Old August 13th 2018, 21:26
DORIGTT's Avatar
Are those Koni shocks the 944 versions? They have a larger lower bolt hole and smaller upper?
Old August 14th 2018, 17:19
Blizzard's Avatar
No the koni"s are for an IRS beetle. I have made the lower urathane bushing out of a set of 19 mm front swaybar bushings and a friend with a lathe made the steel inserts. outside 19mm. inside 14mm.
Old August 14th 2018, 17:27
Blizzard's Avatar
To give an other posible answer to your problem. Are the torsionbars all the way in the splines of the springplate and the torsionbar housing on the chassis. ? Try cleaning the splines in the springplate to see if the torsion bar can go deeper. Hope this helps.
Old August 15th 2018, 18:00
you need to use late IRS covers as well
