View Poll Results: Suspension set-up options?
Red9design coilovers 7 50.00%
Koni (which ones) + adjustable beam 4 28.57%
Bilstein (which ones) + adjustable beam 3 21.43%
Voters: 14. You may not vote on this poll
Old September 24th 2005, 15:29
kleinporsche kleinporsche is offline
That's right Lazy, I want something ride adjustable and rebound adjustable. I'm impressed by what you say about Aldan's set up; is it still the $420 set up?!?! That would be great. Also, while looking at some different options I thaughtabout Spax G616 coilovers: I've read these are the same red9design uses. I'm I right to say that buying those spax with rods from Pacific Costoms, or what not, would basically give you a Red9design kit? Only thing is, I cannot find a source to buy Spax in the Canada or in the US... I heard they're pricey aswell.
The Spax thing led me to a whole reflexion. Correct me if I'm wrong but I think you could use pretty much any rear golf coilover socks for your front balljoint beetle.
Old September 25th 2005, 04:02
lazylongboarder's Avatar
lazylongboarder lazylongboarder is offline
From what i've heard and seen, Aldan is a great quality shock. Also the prices are fair. I can't speak out of expirience because i don't have any, but from the times that i've talked to them and what i've heard, they have great customer service. I'll probably end up doing their shocks up front so I can get my car going sooner then add the 993 front end. I don't know?
420 is what they quoted me a month and a half ago.
1974 type 1
Turbo 6 piston brakes at all corners
Project is taking all my money and it's all Germanlook.com's fault!
98' Audi A4
93' T-Bird (oh yeah!)
90' 911 C2
74' beetle
Old September 25th 2005, 14:48
QA1 double adjustable
click on "Coil Over Shocks" under Part Type
then "Yes" under Universal application
then "Double adjustable" under Coil-Over Shock Type
Old September 25th 2005, 21:18
Volkdent!!!!!!!!! $%#@$?%&?@ It's about the same price as a set of Konis!!!!!!! Totally impressed. Are they good? And which one do you use? Since it's universal.
Old September 27th 2005, 00:41
What I do know is that I own a pair, they are well built, adjustable, and rebuildable. I have the single adjustable version. I'm going to assume they are entry level, but they are adjustable and I really think that most things are going to be better than stock, especailly at this price. Volume is the key for the price, and if their quality control is in check, they should be fine. I bought mine from a reputable motorsports suspension shop who deals with the range from bottom of the line to Ohlins, and they thought they were a very good value for the money. I have no comments on usage, as I have yet to have my car on the road, but I really think that especially the double adjustable has to be such a good deal for the money and compared to the competition. QA1 is either owned by or purchased Carrera, to give you an idea of what level they are at.
Old December 7th 2005, 17:40
Volkdent, do you know which QA1 coilover kit would fit the front of my ball joint standard beetle?
Old December 7th 2005, 22:21
I think it will depend on what your ride height will be and what sort of travel you want. I think they make a combo shock that has an eyelet on one side and a rod on the other, so you should be able to make that one work. Look on Summit Racing's website under suspension and look at the different shock styles they have. They are quite adjustable, so valving shouldn't be a problem.
