#16
Cool GL T1.
Will be watching this @ Hebster: You can use this, simple and cheap, I've tried similar, works fine! I had them on my 1967 for two years, much better visibility http://cgi.ebay.com/36-TOP-LED-Car-T...ht_4063wt_1139
1967 Bug |
#17
So since getting new tires, i've gone and decided to tub the front end, because it was too close to the tires and i was afraid theyd rub once the bus is full of interior.
So we went ahead and cut em out! and since we are tubbing the wheel wells 2" the seat rails need to come up and this was how it was decided to do it... Got done raising all the seat brackets... Cutting an fitting... starting to fill in the void... this piece started out flat... kinda made a break/jig to get it this way... here it is tacked in place the whole front tacked into place after making a few more "fun" pieces... decided to change a few things around on top so it lines up better... pretty much it for the pass side... still have a lot of finishing work to do... |
#18
Love keeping the metal looking stock. The flip flops gotta go while welding though (if it was me)
1970 T1 W/MassIVe 2913cc RAT/?EFI? w/direct fire (very soon) and 915 trans 1962 SC 1776cc SP 944NA brakes, 993 wheels VKG |
#19
Heh, thats my buddy in the flippies. He never takes them off unless he's riding his Harley.
#20
Oh... Yeah, I cant ride my Harley in "flippies" either... mines a kick start only 93 inch shovel head.
#21
So, not much to report other than i now understand why people use trailer fenders when tubbing their buses. Its a ****load of work to make it look proper. We did manage to cut out the original rear hoop/brace and add our own frame brace. Now we are going to be working on the repositioning of the shock mounts for the rear. The picture im posting doesnt show the 3/16" brace that we made between the framehorns, but i assure you there is one there now.
ive also decided on a color scheme for this project. It will be the original Velvet Green on the top, and Porsche slate gray metallic from the beltline down. Let me know what you think. im gonna be working on this again this sunday, so more pics to follow. |
#22
No photoshoped.... Bodyshopped!!
CUP2 17x7x9 Brembo.w.Servo&Master.Cylinder/IRS/CB Dropped Spindle GTI 2.1 16V Turbo Forged/Sapinho/Fueltech EVO-GL |
#23
You're going to run add-on rear 'skirts' like in the picture,
or run factory rear wheel openings? Seems like after taking all of the trouble to tub the rear, you would want to put the rear flares back to stock. And avoid the "Jersey look" cut rear wheelwells... JMHO... |
#24
What im doing to the rear openings is filling them in so it looks 'stock' but using Dzus fasteners so they are removeable. Thats the only way that id be able to get the gigantic wheels out of there. i didnt cut the wheel arch out, that was done by a PO . . . . |
#25
Update: since doing the front wheel tubs, I've had to notch the frame for the tie rods as it sits a good 1.5" lower. I've also picked up a T3 turbo for it. Can't wait till it cools down so I can get back out there.
#26
Don't know why people would do that, some PO hacked my arches too. Had stock ones put back on as the bus is being painted. I'm running 16" MB CLK rims on mine, bus IRS swap with 2500lb. airbags in the rear. Clearance is pretty close on mine but what I do is jack the bus way up, pump up the bags a little which drops the arm down, and remove the wheel by rotating the lower part of the rim to the center of the bus until the top outer edge of the tire clears the apron then pull the whole thing out (hope this makes sense). It's tight but I am able to get it out. The face of the rim is exposed to the ground when you're doing this though.
'66 Bus(11-window, CLK rims, disk brakes, IRS, bags, hydr. clutch, Super-1600 w/injection) |
#27
Front tie rod notches are done. Going to start fabbing the Turbo header tomorrow. Any advice from you Turbo pros?
#29
Ahhh... the memories. From tubbing my bus to having to remove the bolt from bottom coilover mount to get the wheel off. Good Times!
Your project is really coming together! Jeff=
No current VW projects 54 Chevy wagon LS2 AWD 56 Chevy Panel "Lost Cause" VKG Bastage child |
#30
Thanks Jeff! I know what you mean about getting the wheels outta there. That's why I'm leaving the rear cut.....
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
Thread Tools | |
Display Modes | |
