1303 sti project 325hp+ on the road!!
hello
i'm johan and from holland and read a lot on this forum i also have a project off my own i'm now busy with it for 2 year i have a 1303 from 1972 and have done some mods but i started with this front and rear porsche 944 trailing arms 944 disc's and boxter calipers rear mod to unibail coil overs porsche G50.03 964 transmission KEP connection kit a clutch kit subaru ej207 sti engine 2002 runned 36000miles custom intercooler inlets custom wheels 16"steel rims widend front 2,5cm rear 6,5cm and much more also have a full rollcage and doorbars (removaible) did al the engine wiring (big job) custom 3"exhaust magnaflow mufflers custom inlets on the front wing hope it will work to let the airflow out off under wings at high speed intercooler inlets placed the rear windows 15cm inside and airflow is getting out to the original air outlet under the rear window i'm now busy to get the body ready for paint but it is getting slowly i'm also renovating the house this is how the engine look like now custom little wing to improve air flow to intercooler but i hope i can drive i the second half of this year i have also some video's on youtube from the first start www.youtube.com/watch?v=fae2gHi20fE first drive www.youtube.com/watch?v=L1PKfK_BaWE Last edited by johan; October 26th 2013 at 17:48. |
Cool project, I think I have read about it before. I don't remember where. I'm currently searching for some 5x130 steel rims to use with winter tires, and remembered exactly your project, where you said you used some van wheels. Are these fiat ducato/peugeot boxer/citroen jumper rims? They look pretty nice on the bug..
www.vw1303s.com |
i have them from a opel movano need the maxi type off the van's here's a link http://www.steekmaat.nl/omgekeerd.ph...x130&naaf=78.1 |
looking good, how far forward did you have to move the transmission?
Welcome to the GL forums Johan. Lots of nice work going on with your 1303. Keep up the good work!
1970 T1 W/MassIVe 2913cc RAT/?EFI? w/direct fire (very soon) and 915 trans 1962 SC 1776cc SP 944NA brakes, 993 wheels VKG |
Good to see you here
http://www.ricola.co.uk |
thanks
thanks for the comments also you rich!
Really cool, glad to see your definately not taking the normal route! Keep us posted, looking forward to progress shots.
it fit's under the bonnet but not more then that |
1303 sti 325hp+
long time ago
but i thought showing how it is looking now intercooler intake both windows are moved 15cm about 6 inch inside in the rear outlet is under the little wing on the back youtube: http://youtu.be/-2wilTC5Cs0 http://youtu.be/GrFrrbbncL0 http://youtu.be/fae2gHi20fE http://youtu.be/L1PKfK_BaWE car spec: VW 1303 beetle 1972 engine 2002 subaru wrx sti (bugeye model) ej207 sti engine VF35 turbo engine is stock ecu: 2002 sti jdm ecu (i used jdm ecu because no need of immoblizer and keys instead of euro models) ecu is ecutek remapped to 98 oct fuel and runs around 1,5 bar boost should have at least 325hp+. it is not been on the dyno yet rev.limit 7800rpm i can get 120klm (75mph) in second gear exhaust: custom made 3" stainless steel with 2 magnaflow 4" mufflers i'm driving with DB-killers it is now 2 times 2,25" but it has no influence on the power or spool up of the turbo but driving without db killers makes it like a rally car sound there is a youtube link above gearbox: porsche 911(964) G50.03 5 speed gearbox incl shifter that is modified to custom shifting linkage clutch adapter kit KEP: adapter kit sachs stock 911 pressure plate and high performance 6 puck kep clutch plate spec can hold up to +/- 850nm suspension front: fk-coil overs 944 hubs and brake discs porsche boxster brembo calipers custom made steering arms/rods custom made stabilizer bars(cupstrebe rear: 944 suspension arms and brake discs porsche boxster brembo calipers custom made stabilizer bars(cupstrebe) red9design uniball system spax coil overs wheels/rims: steel rims 16inch rear245/45/16 front215/35/16 pre 65 chrome covers fenders front fully steel: front widened 2,5cm 1 inch rear widened 6,5cm 2,5inch fully roll cage incl doorbars 2 gt3 racing seats 4 point belts omp steering wheel 2002 sti instrument cluster boost, oil pressure and oil temp gauges. and much more i have to do some little things on the interior and polish the paint and i need to make a front splitter because when doing around 200klm (125mph) it is getting to search on the road a i need to do little steering corrections just like in old porsche's i going to make a splitter in the front to improve this when it is doing better and i can test it on the autobahn next year (i'm from holland and live 15klm from the autobahn ;D ) hope you like it |
WauW !!!
No useless sh*t on my roofrack !! |
1303 sti project
Nice project with some smart mods
I thought of the rear window air intake but I had already had the car painted,I think that is a very smart.Ive seen your car on youtube keep us posted with the videos.
gee dub |
New video with new camera
Made a new vid
Wiht a hd cam But when i was home again it was on 720p and not on full hd But still nice to see i think Next will be on full hd http://youtu.be/ldYdgGaC22M It is al most fully done I bought a kamei spoiler that will be fitted and i have to do an splitter And then it is 100% ready |
got new video sprint 0 -200klm
wheelspin in 1 gear and to early to 2 gear but still pretty fast!! but only the audio is still problem that i need to fix sorry about that http://youtu.be/PG10E8_utiI reaction video of a mate http://youtu.be/ri5BRdfaQ1s |
Installed a kamei spoiler and made a splitter underneath
For more stable drive at higher speed Around 180 the car is getting light in the front When i get enough downforce I will do a autobahn run soon |
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
Thread Tools | |
Display Modes | |
