Old August 16th 2002, 17:19
MattKab's Avatar
MattKab MattKab is offline
How much has the steering been limited on the Silver arrow?
Are those wheels just for show?
Awesome Bug tho'.
My 17's no longer look big!
23" alloy wheels on display at the Tokyo Motorshow last year mmmmm 23inch !
Old August 16th 2002, 22:19
Superman
Originally posted by bren
quote:
Originally posted by Superman
and Topline has the spacers that you will need (with VW brakes)
a 7.25" rim with ET40 (ET is offset BTW) wouldnt need spacers...
Spacers will be needed to clear the stock springs on the Super's strut. However, if the MaXX strut (small diameter spring) is used then the spacers will not be needed.
I once fitted a 15x7" ET38 wheel to an early Super and needed a 1" spacer to clearance the strut... that was in 1995 before the MaXX strut was available.
Old August 18th 2002, 17:49
69_Dreamz
Hey superman, when you put that 15x7 with a 38mm offset, did it limit your turning radius at all?. I have 17x7 with a 38mm offset on my 69' bug ball joint front end, It seams that it has really limited my steering, this is even after adjusting the steering stops. Any advice for increasing the turning capability of my front end?
Old August 18th 2002, 17:57
Superman
Not really, I had to adjust the gearbox stop, but mine is a Superbug with a completely different front suspension than a '69, so there is no comparison.
Old August 18th 2002, 18:01
Superman
Ask Bren (in the suspension forum), he can help you with the Standard Bug torsion bar front suspension...
...I only know Supers.
Old August 18th 2002, 18:03
69_Dreamz
thanks for the reply Superman, I'll drop Bren some mail now.
