#16
Thanks to your tech article I have finally decided on my dash.
I have been undecided for years.
I love my money pit, uhm, err, I mean my car. 1969 beetle in the works... 2.0 type 4 DTM... 2004 Suzuki GSX-R 1000 crashed www.volksport.net Volksport Kfer Gruppe |
#17
Glad you got something out of it. I like mine.
NO_H2O 72 1302 Smack Black GL 73 Bus (2L CIS Powered) 66 Beetle, 73 Standard Beetle 72 Pinzgauer 710M Volksport Kafer Gruppe |
#18
Now if I could only figure out what I am doing with the rest of my car.:befuddled
#19
I konw what I want to do and what my $ (or lack of) will let me do, what I get is somewere in between.
#20
It's so hard to find the middle ground. I have expensive taste. I'm really cheap. It's an ongoing battle between my bank account and my bug.:silly:
#21
YEP, I know what you mean. I'm livin' it.
#22
Looks very cool and goes well with the theme of the car, I like it a lot.
#23
Thanks Nigel, I bet it would look great in a yellow and black bug too.
#24
i saw a set of 16" Fuchs the other day...hint, hint...nudge, nudge...wink, wink.:silly:
#25
hi
can somebody tell me the outside diameters of those gauges please i wonder if they fit into the stock openings of a typ3 dash??
neil verdon 66 sqr on irs. |
#26
the Tach is just over 4 1/2 inch and the others are just over 3 3/4 inch.
#27
hi
thank you i will look to see if there going to fit my sqr tommoro.
#28
Well I finaly got to take the car out and drive it for about 2 hrs. The speedo registers about 5-7 mph high on the freeway as did the bug speedo due to the 195/50/16 tires on the front. and the gas gauge sweep it slower than the bug, ran out of fuel just before it got to 1/4 tank. At least I ran out while I was opening the gate to pull around to the back of the house and put it in the garage and had some fuel in the shed to get it inside. (note to self, fill up when gauge reads 1/2 tank).
#29
I ran out of gas in the gas station about 20 ft. from the pump. Talk about cutting it close.
#30
hi
ok hate to be a pain but can i gat a real acurate mesurement of the size of the back of the instruments from somebody please not across the face but the bit that go,s into the hole on your dash . the typ3 dash openings are 105mm and 85mm so this is for 100 and 80mm gauges ive a feeling unless i go for some form of custom dash in a typ3 im stuck with stock!!! mesurment given before 41/2 inches equates too 113mm was this across the face or the housing 3 3/4 =94mm. i think im stuck
