The top mount version would provide safety if the mount failed, but would seem to make removing the tranny quite a bit more difficult, as well, when the tranny is loaded during acceleration, the top mount will be in expansion, not compression, and this force is going to be working every time you accelerate.
As well, as I recall, those mounts have a bolt running through them, not just into the rubber, so the safety is there regardless? Might want to look at more modern motor and tranny mounts, if your fabbing up might as well make use of something with a better design? My 2 cents... Jason
If I could just get paid for my sleepless nights.... 1960 VW Bug UBRDUB Walkaround 1st Drag Run Dyno Run Oval Ragster-'57 Rag/'04 Boxster S |
With the upper version you just loosen the rubbermounts and pull the whole thing. An other aspect would be that when you "motor brake" or how you say it the upper version will just compress the rubbermount where as the lower mount will expand the mount. Same thing also with no power on the drivetrain the weight of the engine and transmission will tend to expand the rubbermount. I'm now trying to find a original 911 mount including the rubbermounts as those work differently, not just two plates with molded rubber in the middle. If I use these I think I can make the lower type (original 911 style) with no problems...
I didn't want to cut the torsion tube either, but I did want to lose the torsionbars.
I have coilovers on my splitbus at all wheels. At rear with a rocker-system. More about suspension at page 7 in my project topic at vdubheaven.com. ![]()
Skywalker, why the rocker system? I can't see the advantage of it in your application, but it does look cool!
I can see the advantage. I'm in the same dilemma. Lack of room, you can see that the joint that goes down to the stock shock mount is in an angle.
You couldn't mount the shock in that angle. |
![]() @Steve, thanks. There's still some work to do tho. ![]() Luuk |
hi
I read the build up on that webpage, wow you have really done some fine work, congratulations. Steve
I think there is room for improvement in the rocker though, you could redo the angles so that it acts like a progressive spring, getting stiffer when under more compression, which will let the bus be more stable on hard cornering. I'd also try to get the pivot point in double shear, could you make a bracket to reach over to the other side of the bearing? Definitely another nice project to follow! Rich
http://www.ricola.co.uk |
Thanks Rich. I appreciate you input, but I have to set a line some where... Same as with the brakes. For now a drum at rear, if it does not meet my standards I simply can go for 944 discs after the bus is finished.
The oil pressure in the shock mount is already adjustable and I 'm not building my bus for the racetrack. The suspension will be a lot better as with the torsion bars. It 'll do I guess. ![]() Luuk |
The 901 frontmount arrived yesterday. I decided to use stock 911 rubbermounts instead and will now adapt that to the steelplate I have made for my transmission. This will atleast work correct from the underside too..
![]() The two others are the rear enginemount rubbers... |
Several very impressive projects!
Makes me miss my old girl. Jeff-
No current VW projects 54 Chevy wagon LS2 AWD 56 Chevy Panel "Lost Cause" VKG Bastage child |
Took my VW flywheel to a friend of mine who makes race parts etc. himself. I also gave him a 911 flywheel I borrowed to take measurements from. So hopefully during January I will have a VW flywheel that fits the 911 engine..
Modified the 911 front transmission mount to fit the new location:
![]() Started boxing the rear frames to give more support for the heavier engine.
Nice work on the T/B plates.
NO_H2O 72 1302 Smack Black GL 73 Bus (2L CIS Powered) 66 Beetle, 73 Standard Beetle 72 Pinzgauer 710M Volksport Kafer Gruppe |
