Old February 9th 2008, 08:55
Whatever will do the job, the beauty of Volkdents conversion was the use of factory brakes, stub axles etc.
Old March 10th 2008, 17:56
2443TT 2443TT is offline
I've used a 930 box on my new chassis. There is no way to get it to clear the torsion housing unless you were to raise it 5-6 inches.
I've cut the torsion housing and re-enforced the entire area around it, coil over conversion that makes the back end more rigid. The 930 bell housing is in the same place as a vw one, but about 1.5 inches higher.
I've posted my build up here..
http://forums.aussieveedubbers.com/v...d=66140&page=5
Cheers,
Ian
