Old November 11th 2010, 02:53
Your doing excellent work, I'm taking the body off a 1303 soon so it can be painted, I'm glad that we don't have the same problems down here as you do there.
I might be seeing things but in the photo http://www.keversite.nl/fotoalbum/fotos/99903.jpg it looks like there is some sort bulge on the chassis floor at the rear end behind the seat rails, is this for something special or is it a piece of your bug puzzle waiting to be fitted?
Old November 11th 2010, 05:04
fahrvergnugen fahrvergnugen is offline
Thanks Steve,
The bulge is made to fit the oilcooler, I think this will have plenty of airflow. Good luck with your car.
Paul.
If some is good and more is better, then too much should be just about right!
Old November 11th 2010, 06:04
Nice work Paul! I don´t think I have ever seen anyone make such a big modification for an oil cooler! I like it!
Old November 11th 2010, 07:01
MX67 MX67 is offline
This looks nice. No rear legroom, but who care!
1967 Bug
Old November 11th 2010, 07:05
No rear seat, so who cares
Old November 11th 2010, 09:02
Wow I never would have thought of doing that.
Old November 11th 2010, 12:51
T5WOB's Avatar
T5WOB T5WOB is offline
nice work well done
kerb$ide ku$toms
Old December 13th 2010, 00:53
KAFUR1's Avatar
KAFUR1 KAFUR1 is offline
Slick I like! Hmmmm
Old January 12th 2011, 16:20
Found some time to work on the car again 8)
The underside of the left doorpillar was bad, of course >
time for a Hoekie of Hooky
First I had to shorten it, this way the bracing could stay in it's place.
fitting
It only needs some welding. 8)
Paul.
Old January 15th 2011, 15:37
This morning it was time to finish the doorpillar.
Welded the hooky piece.
Normally you can not reach the inside, mine is still open and it is double sheetmetal so I also welded the inside.
Then I dismantled the door (this is very heavy with all the parts and glass in it) and checked the gap, I must say ; I am very pleased with it.
Paul.
Old January 21st 2011, 03:36
ido vw ido vw is offline
Awesome work Paul! keep update!!
Old February 1st 2011, 12:28
Thanks, I am ill wright now but next week it is time to do some work again.
Paul.
Old February 17th 2011, 15:33
Not much time lately, but still a Little progress.
This piece of the trunk was a little thin, also the holes didn't mach the new kick panel. so I replaced the top of the kick panel by a wider piece, this way I can close (weld) all the holes.
And all the holes are closed again. before paint I will put some lead filler on it and it will be as new again, offcourse I will do the corners first.
Paul.
Old February 18th 2011, 13:15
Bad bug's Avatar
Bad bug Bad bug is offline
Paul where did you get the lower door post panel to buy.
Old February 18th 2011, 15:16
Do you mean that green piece? It's a hooky piece, perfect fit.
http://www.hookyspanelshop.com
Paul.
Currently Active Users Viewing This Thread: 13 (0 members and 13 guests)
