Old January 22nd 2007, 21:19
Veedub Veedub is offline
what would the hp be?
Ok, I have 2 motors, one will go in the bug when its done and stay stock, the second motor will be built up. I dont want a 2L but I want a 1776,1835 or a 1915, or maybe a 1641cc.I want it to be pretty quick but still be reliable.My budget is maybe 4grand or whatever I save up to till the time I'm ready to tear my other motor down.I found a website that shows all the stock specs on the bugs.The motor in my bug(or will be in my bug stock has 65bhp and 86lbs torque, and weighs 1786lbs stock.The other motor is out of a 74 and has 46hp and 89lbs of torque.
I was thinking about a combo, here is one I was thinking of, tell me what you think?This is for the future refference so I know what I want and to be ready, if you know what I mean?
the bore- 87mm,90.5mm,92mm, or 94mm AA pistons and cylinders (they ok?)
Eagle Racing cam-Adv. Duration .276", Duration @.050"-.228", Lift @ cam- .380" Lift w/ 1.1:1 rockers-.417"
Straight cut cam (Would it do anything?)
Super Stock Rhino Rocker arm kit 1.1:1
Dual 34mm ICTs or Dual 40mm Kadrons or Weber 40 IDF's
044 Super Mag CNC round port heads
Springloaded pushrods
Lightened 200mm flywheel
Pertronix Billet Distributor
Pertronix 8mm plug wires
Pertronix black coil w/ 45000 volts
Ceramic coated merged header with a glasspack
I am aware the pertronic ignition system does not increase hp but thats part of the setup
What you guys think it would have for hp?If its a high reving motor that would be awesome IMO, i like cars that rev high, AND DONT TELL ME TO GET A HONDA for saying that
