Starting to get fun. Installed the stock Boxster trunk latch.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Jason
If I could just get paid for my sleepless nights.... 1960 VW Bug UBRDUB Walkaround 1st Drag Run Dyno Run Oval Ragster-'57 Rag/'04 Boxster S |
Devil is in the details. There was a fatigue fracture through this area. Hope this makes it better and the decklid easier to seal against water.
Awesome work!!!
What a great build. I had considered this and your posts have convinced me not to! But Wow will you end up with a nice ride.
Meyers Manx Signature #85 , 79 Convert |
Back at it, just grinding through the details.
Fabbed up these steering column brackets, I now have a tilt AND telescoping steering wheel!!! This little bracket was a lot of work but now I can adjust the wheel for almost any seat or seating position. The nutsert tool is already paying for itself! ![]() ![]() ![]() ![]() Finished up moving the clutch master over 1.75" as well. It's not what I would call pretty, but I'm working on my side under the dash so cut me a little slack. It is all sealed and if I ever do a renovation of this thing I can pretty it up then. ![]() ![]() ![]() Steering column back in and we have steering again!!! ![]() ![]() Finalized the angles, routing, and rotation of the tubes for the cooling system. I think Erik at norcalsandandoffroad got them welded up for me today. I do all the fiddley work and I let the pros do the talent stuff! ![]() ![]() These are the details I'm most proud of, I was able to utilize the stock coolant pipe bracket even though my pathway is totally different. ![]() Jason
Fantastic work! Looks like things are getting a little tight now eh?
Oval bugster
This build is just bonkers
so much work ![]() ![]()
gee dub |
Hi Jason,
Good to see things progressing at a constant pace, nice to see the go-kart, must give some good motivation! I might not be commenting much but rest assured I'm watching ![]() Rich
http://www.ricola.co.uk |
More coolant work. Had to "massage" the area above the front lower control arm attachment point to allow space for the rad. Not pretty but necessary. Also welded a tunnel through two body layers for lower rad hose.
![]() This is where the tunnel exits, then up and over the rack bellows. Tight fit. ![]() The top and bottom hoses join next to the gas tank. Also this is a high point for the lower tubing, so a bleed bung has been added that ties into the stock Boxster coolant bleeding system. Hopefully this makes for trouble free bleeding. Very excited to be able to use the factory coolant hose bracket! ![]() The previously dual rad system now only has one pathway. Both side bleed tubes can be seen and will be used. On a technical note, I am now aware that there are special hose clamps for silicon hoses. They have an additional internal sleeve that offers a smooth surface for the silicon to be squeezed by. ![]() ![]() I've been able to just squeeze this monster in there, next up add the A/C condenser... ![]() Jason
If I could just get paid for my sleepless nights.... 1960 VW Bug UBRDUB Walkaround 1st Drag Run Dyno Run Oval Ragster-'57 Rag/'04 Boxster S Last edited by volkdent; September 9th 2013 at 02:59. |
Coming along Jason. Very cool project!
Small update, big progress.
I finally got the floor pan welded to the frame. It sounds simple enough, but the floor pan has a nice thick layer of German underbody sealer on it, and it all had to be ground back from the welded edge. A big mess. Then, to make it just a little more messy, I seam sealed the whole area. I forgot to get a pic, but I used a honey consistency seam sealer so I could really flow it into all the nooks and crannies. Trouble is I'm doing this upside down so I looked like I pigged out at the chocolate fountain... Also got a jack point welded in, seen it the top part of this pic. Anyway, here's a shot pre-sealer. ![]() And a couple more of the rad area. ![]() ![]() Jason
Just curious about something, I scrolled back a few pages but maybe I missed it. How does the wheelbase look front to back? I mean does the top curve of each wheel line up with the curve of the fender? My super was in an accident years ago and I went through quite a bit just with small changes here and there to get everything to line back up.
'66 Bus(11-window, CLK rims, disk brakes, IRS, bags, hydr. clutch, Super-1600 w/injection) |
I can't see a difference, although apparently there is one. Keep in mind I have fiberglass fenders, so it's really easy to modify the opening too. I believe the difference is less than 3/4"' and I like my front wheels a little tucked forward a la Foose.
More body mods. Not too many things good about getting old, but a couple are patience and knowledge, so I scraped up as much of each as I could and this is what happened.
