Old February 12th 2005, 07:55
judgie's Avatar
judgie judgie is offline
set up help
have a 03 with 944 running gear,tca's are also rose jionted on the inner end.
running 7x16 front and 8x16 rear,type 4 motor,stripped out interor.
looking for some base settings on front camber and castor also toe.what should i be running the camber and toe at?
car is going to be used for sprints/hillclimbs and track days so needs to have very good turn in. not so importent stright line stabilty.
was thinking along the lines of 3*front camber and no toe in/out.and 2-3 camber on the rear with teo in.
any ideas?
cheers rob
Old February 12th 2005, 09:24
puma-Alex puma-Alex is offline
Here are som links to the topic , good luck mr !
http://www.ozebiz.com.au/racetech/theory/align.html
http://aircooled.net/gnrlsite/resour...s/handling.htm
Old February 12th 2005, 13:32
judgie's Avatar
both links give good guides into what dose what,but what im after is a starting point,somthing to work from.was hoping someone who is still active in the kafer cup or simaler is out thare and is willing to help.
cheers rob
