Type 1 DTM shroud... what lower tin?
Hey Peeps! I got a question. I am currently running a type 1 DTM shroud and the lower tins i have on there are the flat square things with 2 tangs sticking up on each side that go between the 2 cylinders.
My question is.. I was reading on another forum and they said to use the whole cylinder shroud piece as seen here.. http://www2.cip1.com/ProductDetails....C%2DC10%2D5444 So.. should i ditch the little square dealies with the tangs and go with the whole shroud piece? I read that Jake R said that to make efficient cooling you need to make pressure.. so im wondering if i need both tins on there? Thanks a million. Scott |
I am running a T1 DTM on a 2275cc. I was one of the test monkeys. I do not run lower tin on mie. I do have the defuser tin(stock snap in)above the push rod tubes. I have had no trouble with cooling the heads/cylinders.
By a newsletter released by VW back then, those cool tins were designed only for the type 3 cooling systems and should not be use on type 1 cooling system(similar to DTM), states will run hotter.Personally I do not have a copy of that newsletter, but neither had any problem with the orignal type 1 ones.
Onix |
Ohhhh awesome!!!! Saves me some work!!
my engines a tad smaller than yours NoH20 so i should have no prob Thanks for the replies! |
you can always call jake and ask. or post on his forum. he is good about responding...although he is slammed at the moment. one note on no_h2o's engine. it has big jugs, so that may automatically provide some back pressure without the tins as compared to stock or smaller jugs.
zen '73 2316 TIV GL Standard Bug (quasi) Company Branding, Graphic Design, and Web Services at DigiVinci Design |
The Type I DTM was developed with the stock Type I tins. It was designed to work with the backpressure and resistance created by these tins only.
Avoid all other tins- Period.
Jake Raby |
Cant argue with the master!
Thanks!!! :bowdown: |
Scott, did you get my email..
Jake Raby |
Nope didnt get it..
Ill PM you with both emails just in case. doh!! you pm box is full. I shouldda known that. Email is in the profile.. maybe its just slow. |
