Old July 30th 2008, 13:54
tmcdade tmcdade is offline
Early Turn Signals on Late Beetle
Could anyone tell me if I can use 69 beetle turn signals on my 72 super beetle? I didn't know if both used 12 volt, and if it would work out. Thanks
Old August 1st 2008, 08:27
oasis's Avatar
oasis oasis is offline
Yes, they are 12-volt units.
In the US (my assumption since I don't know where you reside), the 1964-67 turn signals used the same base as the 1968-69 turn signals. Therefore, you would need to swap the entire unit.
Also, the 1970-77 turn signals have two separate bulbs -- one single-filament bulb for side lighting, and one double-filament bulb for "parking lights" and flashers. So while you may have some body work to do as you fit a smaller unit to the fender, you may also have a wiring issue to resolve.
I am sure none of this requires extravagant modifications.
(2004-2008): 1971 1302 w/2056
