Old July 21st 2003, 13:34
ShApE's Avatar
ShApE ShApE is offline
need help with windows
ok today i got bored and decided to take out my windows since my car will be painted soon.So i started cutting the rubber (ordering new rubber) and i had all the windows out except the driver and passenger sides i started to cut then i relized i had no idea how to take these windows out so i looked around the inside of the door and saw 2 bolts and im not sure what to do. so do the bolts hold the window in? if so what all do i have to do to get them out? any help would be apreciated!
-= 71 super =-
-= 86 944 turbo =-
-= 84 911 carrera (dad's) =-
-= 76 cadillac seville (me & dad's) =-
-= 2002 toyota sequoia (brother's) =-
-= 99 ford explorer =-
-= 2005 Cayenne S =-
Old July 21st 2003, 14:18
vujade's Avatar
vujade vujade is offline
I just took all my windows out of my super last week, so I can help you with this.
First, what you want to do is roll down the windows.
then, pull out the window channel first with a flat screw driver.
then you can take out that screw that is at top up near the vent windows.
after this, you will need to remove the chrome trim that is around the windows. this is held in by the screw and some clips.
Once all of this is done, you can then take off your door panels and remove all bolts inside the door that hold in the window and the regulator. The window will pull thu the top of the door once it is unbolted.
The regulator will pull thru the opening where the door panel used to be.
The vent window will come out too after it is unbolted.
WinterJam 2010
Old July 21st 2003, 20:27
ShApE's Avatar
alright thanx vujade!
-= 71 super =-
-= 86 944 turbo =-
Old July 21st 2003, 20:49
ShApE's Avatar
ok i just went out and looked around. what do u mean by channel and also what screw? is it inside or out?
-= 71 super =-
-= 86 944 turbo =-
Old July 21st 2003, 21:47
vujade's Avatar
ok, the window channel is the rubber that fits up inside the door frame that goes around the window.
as far as the screw goes, once you pull out the window channel, there should be a screw up inside the door near where the top of the vent window on the inside of the door frame.
Sorry if I am not making myself clear enough
WinterJam 2010
Old July 22nd 2003, 15:25
ShApE's Avatar
no its cool man i just wanted to double check before i started.
thanks
-= 71 super =-
-= 86 944 turbo =-
Old July 27th 2003, 19:36
you're a couple of pictures shy of a tech article vujade.
zen
