Old June 16th 2004, 20:44
yellow73's Avatar
yellow73 yellow73 is offline
Dave, good luck with the install, hope it is ready for Saturday. :agree:
Old June 16th 2004, 20:51
I got it apart and cleaned when I woke up today. I will have to pick up some bracket material for the fans and mounting brackets. I also need to test the thermostat.
Old June 17th 2004, 18:59
I picked up some bracket stock and tested the RX7 cooler thermostat(checks good). I also took apart the old fan brackets so when I get up tomorrow I will start the fab./installation/electrical. Then try to get some road time to test it all. Then I still have to clean the car up, it is kind-a nasty right now.
Old June 17th 2004, 22:29
Mikey 1972GL Mikey 1972GL is offline
Glad to hear everything sounds to be working out. :agree:
Mike
My new user name, Mikey
for some reason, I havn't liked this name since I made it.
Sorry for any problems... Mike
Old June 17th 2004, 23:12
yellow73's Avatar
Dave,
Your car kinda nasty looks better than most at their best
Old June 19th 2004, 00:52
Well the cooler is in and it seems to be cooling great. As we(Boygenius and I) were driving thru Stockbridge we lubricated the aft drivers underside of the car and a short section of hwy 138 when the line to the cooler blew off. The lines to the RX7 cooler are slightly larger than 1/2" so after a trip to the 24 hr. Auto Zone with no joy we will try to find a pair of 5/8 barbed fittings to properly connect the RX7 lines to the rest of the system at Home Depot in the morning. If I can't find then I will be up in the Beater Bug.
Old June 21st 2004, 00:43
Dave, after I made that post about coming over I didn't check for your response, I went to bed. and I didn't realize how far you were from the show or I would have planned to leave sooner, like thursday morning The Wellesley Inn was great. fridge, stove, dishes... like a mini apartment, for the night. I would have liked to come help. I'll plan better next time, hopefully you won't be needing the help. but if so, I'll be there. :agree:
Mike
Old June 21st 2004, 09:02
Don't worry about it Mike. I had plenty of help. Just needed the right parts. I could have had 50 people here and the out come would have been the same. I should have had the thing in a day earlyer but I had to work.
Old June 21st 2004, 15:56
kenfyoozed kenfyoozed is offline
did you have any RUDE neighbors asking you to stop all the loud noise after midnight? if not great neighbor hood! Zen needs to get into a place like that!
Neil Robinson
REMEMBER ... think VW not PORSCHE
Old June 21st 2004, 16:16
I understand you needed the right parts, to do the job right, but I still would have liked to help, and hang out too. Maybe next time.
Mike
Old June 21st 2004, 18:16
haven't seen the guy since either.
zen
Old June 21st 2004, 19:21
Nope, no bitchy nieghbors. But the "High Pressure Line and Fitting Ferry" didn't visit us either. I like out in the sticks compared to Zen.
You are welcome to come by and help out any time Mike. I had plenty of Brats, chips, beer and 10W40 to go around.
Old June 22nd 2004, 00:05
I'm not sure about the beer, but the rest sounds good. Thanks for the offer. I can't wait till I can take you up on it, if I lived closer I'd try to help with the 901 install, concidering I'll be doing the same thing sooner or later.
Mike
Old June 25th 2004, 23:30
Pillow's Avatar
Pillow Pillow is offline
The Volvo coolers blew! Jess, how much oil pressure are you running there?
Dang, sorry about that. I thought those coolers were the cats meow for a Beetle install. I wonder if the Volvos have some pressure limiter before the cooler that I am unaware of, or thermovalve where they do not get a jolt of cold thick oil?
The RX-7 coolers are great. I got my adapters from www.mazdatrix.com for the 10AN lines. Not cheap fittings but the only game in town that I know of. The problem is mounting the huge thing in a Beetle.
Good Luck Dave!
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old June 26th 2004, 00:11
boygenius's Avatar
Good Luck Dave!
I didn't think $9.50 each is bad if you figure out what it would cost to get some fittings TIG welded in place.
