Master cylinder bore size
Does anyone know what bore size of master cylinder should be used for following brake system configuration?
Front - Wilwood 4-pot calipers 44.5mm bore size Rear - Wilwood 4-pot calipers 35mm bore size I will be using Tilton dual mc pedal with balance bar. Thanks Tim |
Steve C or H2OSB can do the calculations to answer this; however, a Wilwood rep. should be able to answer this on the phone.
