Old February 7th 2007, 22:00
Veedub Veedub is offline
GT Wheels
Are these considered GL? Well at least a little bit?
These are what I'm talking about except in a 15x5.5 and I'm just using these as and example.
http://www.thesamba.com/vw/classifie....php?id=419016
I think my bug would look cool with them but in a silver or polished version.
Old February 8th 2007, 09:39
fastdub fastdub is offline
nope
stock widened steelies are more GL
Old February 8th 2007, 09:58
But theres a porsche version so
Old February 8th 2007, 17:17
dont make em gl
and im not sure there is
Old February 8th 2007, 17:43
EvilAngel's Avatar
EvilAngel EvilAngel is offline
AFAIK those only came with special edition bugs. But i may be wrong...
________________________
1990 Mex-Spec GL Bug "The Blue Flame":
Engine: Planning Stage
Transmission: Planning Stage
Suspension: Front: 3/4 swaybar w/UrethaneBushings, Dropped Spindles. Rear:CB Camber Compensator. Lowered 2 splines
Brakes: Front Brakes: 280mm solid rotors, two pot calipers. Rear: 280mm solid rotors, 1 pot calipers w/ebrake
Old February 8th 2007, 17:50
Pillow's Avatar
Pillow Pillow is offline
I would not consider them GL either.
Actually I do not think they look good at all. PLus they are so skinny you cannot fit decent meats on them!
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old February 8th 2007, 21:07
yeah stock wide ones look **** loads better
Old February 8th 2007, 22:23
They were also available on the 914's. The 914's had a 41mm opffset, the ones for the beetle had a 27mm offset. Guy on thesamba told me.
Old February 8th 2007, 22:28
EvilAngel's Avatar
That would mean the 914's are wider (right?) Other than the look, which shouldn't mind since your car isn't a strict GL, the problem is that they can only accomodate skinny tires, as mentioned above.
Old February 8th 2007, 22:33
Well the ones for the 914 wont work on a bug at all. If skinny tires can only be runb on them Im not gonna go that route then.I was gettin a set of 4 for free.
15x5.5's but i wont now But I dont understand why you couldnt run a wider tire on them, oh well.
Old February 8th 2007, 23:41
Timmy_Barns's Avatar
Timmy_Barns Timmy_Barns is offline
Kinda off-topic, but are Fuchs considered GL?
99 Mk3 Jetta
Don't take life seriously because you can't come out of it alive" --Warren Miller
Old February 8th 2007, 23:51
I think they can be considered GL or CL, depending on whats done to the car, my car follows no look really
Old February 9th 2007, 00:39
EvilAngel's Avatar
Yes Fuchs are GL since they are porsche, however the CL crowd also use them.
Old February 9th 2007, 10:51
oasis's Avatar
oasis oasis is offline
I think part of the confusion is the link has a pic of a 4½-inch wide wheel. I realize the pic is an example of the 5½-inch wide wheel you want and not the actual set of wheels themselves, but I needed to re-read the entire thread to be reminded of that. This sometimes happens as threads get extended into multiple posts.
Obviously, a 5½-inch wide wheel can accept wider tires than a 4½-inch wide stock model.
The 914 was a VW-Porsche joint venture. Only in America were they marketed as Porsche only. The wider wheels were available for the 914 and on some Volkswagen special editions with offset being the difference. I don't know the offset numbers but what the Samba source said rings true.
The difficulty with a stock bolt pattern is there are not very many German Look options available. And what is available is sort of borderline. Changing a stud pattern is an expense. Some are less expensive but a bare minimum would be considered inexpensive by most definitions.
Do what you have to do; do what you want to do within your parameters.
Old February 9th 2007, 11:01
EvilAngel's Avatar
Well I know that 4 x 130 is not a common pattern, but i've chosen these:
17 x 7 wheels, specially designed for a bug
Would you consider them GL?
