Old December 24th 2006, 10:38
Bad bug's Avatar
Bad bug Bad bug is offline
white line sway bar.
Good day guy's,
I was looking at the whiteline sway bar this morning on the net and a question came to mind. Would a berg intermediate mount interfer with the placement of the rear sway bar in anyway.
Old December 24th 2006, 16:10
Don't know that, but I can tell you a 915 tranny with its nose mount does interfere with the white-line sway bar...
Old January 4th 2007, 12:55
65Cabby's Avatar
65Cabby 65Cabby is offline
I've got both on a IRS rear and they don't although mind is a Berg 5 Speed nose but that is larger than standard. The whiteline bar runs across under the torsion tubes and comes out near at right angles to the lower shock mounting. I'll post a picture of what I have later tonight.
Old January 4th 2007, 13:51
Bad bug's Avatar
65cabby, Please post photos and thank's in advance.
Old January 5th 2007, 09:51
65Cabby's Avatar
this is the only picture I had that shows off the area.
Old January 5th 2007, 09:52
65Cabby's Avatar
But as I'm working from home today here are a few more.
Old January 13th 2007, 15:44
Correction: It DOES fit!
Walter
Old January 14th 2007, 04:46
bug-er's Avatar
bug-er bug-er is offline
Is there a uk supplier for whitebars?
thanks
Old January 18th 2007, 12:09
shuff shuff is offline
White line.
Hi Guys.
65 Cabby did you get your sway bar from the place in Scotland as listed on their website ?, and is it an 18 or 24 mm item.
Old January 18th 2007, 19:38
65Cabby's Avatar
Unfortunately it came alot further than scotland , it was direct from Oz. The co.uk web site now has lots of UK resellers, you'll just need to price it up as I'm sure they will not hold stock so will end up being shipped, just not direct.
The rear is a BWR1Z which is a 24mm bar.
And in case you are interested, the front is also from Whiteline it's a BWF8Z (SBS2) 20mm narrowed version. Not because of the current tucked in wheel look but so that the 7" wheels look right under the standard front wings.
