Old November 13th 2005, 23:23
lazylongboarder's Avatar
lazylongboarder lazylongboarder is offline
I have no more patience...
1974 type 1
Turbo 6 piston brakes at all corners
Project is taking all my money and it's all Germanlook.com's fault!
98' Audi A4
93' T-Bird (oh yeah!)
90' 911 C2
74' beetle
Old November 13th 2005, 23:49
That's funny. And your doing what to your car.....?
Old November 14th 2005, 22:46
Here's the steering shaft. The stock outer housing has been shortened and will need to be shortened some more, and the main steering shaft has been shortened as well. It will have the intermediate piece slipped inside it and welded. Residing inside the housing is a machined Delron(if I remember correctly) bushing that limits lateral movement of the steering shaft. A new bushing will be machined and pressed into the end of the housing to rub up against the Ujoint to limit in/out play of the steering wheel. Don't tell anyone, but the Ujoint is AMERICAN!!! Its a Flaming River hot rod one, but I could only find a guy that made standard splines on shafts, no metric. Ever try to find someone that makes splines? If you want to spend LOTs of time, give it a try someday.
Old November 25th 2005, 23:14
Ya you got me...
by the way, i'm ordering the 993 rear suspension assembly on Mon. the 28th and i got my ej20tt a month ago. The biggest thing i'm saving up for so i can really start fabbing up some shizzle is the 6 speed g50. Too bad its $3500 then 1100 for a lsd, with 500 hp and 400 lb/ft of torque, i don't want to worry about 1 wheel burnouts.
Good luck with your project, its looking great!
1974 type 1
98' Audi A4
90' 911 C2
74' beetle
Old December 21st 2005, 03:28
The steering is now complete. I'll get pictures soon. I had to enlarge the hole for the steering shaft at the front bulkhead by about double towards the midline to accomodate the steering shaft angle dictated by the rack location.
A friend of mine machined a spacer for the end of the steering column to resist in/out sliding of the steering shaft. It inserts into the end of the steering column and rides on the edge of the Flaming River U-joint.
It should work out really well, but it uses the stock 1960 steering wheel. It's very "sleeper" but I'm afraid I'm going to have to do it all over again with something I can use the Porsche 996 Tiptronic steering wheel on.
Old December 21st 2005, 12:32
Panelfantastic's Avatar
Tiptronic? You don't have an auto, do you? Just want the buttons for something else?
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
Old December 22nd 2005, 04:31
I figured I could use one of them for the volume control, and the other to shoot laserbeams!!! Seriously though, 2 possiblities, full track/volume control, or they have this sequential shifter that comes out of racing that could be used to shift. I'm thinking those buttons will be used for volume control for a LONG time before that tranny will get into this car though!
Old December 22nd 2005, 10:10
Sequential... yummmm !
Jeff-
VKG Bastage child
Old December 22nd 2005, 19:57
MdR's Avatar
MdR MdR is offline
UK Interest
+44 (0)7812 167547
martinandsonjaATf2sDOTcom
Old December 31st 2005, 02:22
darren's Avatar
darren darren is offline
I watched one of these go on Ebay uk last month for £600! Factory fitted LSD, less than 5K miles.
I knew I should have bid on it
Old December 31st 2005, 02:39
OK, IF ANYONE FINDS A DEAL LIKE THIS LET ME KNOW I'LL GIVE YOU MY CELL # SO I CAN FIGURE THIS OUT ASAP! come on. thats soooo cheap for a g50, i'd've definately gone for that and eaten the shipping. Sorry volkdent for killing your thread. It seems that this is the most popular thread and everyone checks here the most...including me.
Rock and roll, the rear suspension is here, so is my motor (to bad i'm only gonna use the heads off of it), and i'm still looking for a good deal on a g50.
1974 type 1
98' Audi A4
90' 911 C2
74' beetle
Old December 31st 2005, 02:52
darren's Avatar
I should add it was a '95 year box and the porsche forums i looked up suggested avoiding these early year boxes.....
Old December 31st 2005, 12:55
Darren, sweet looking panel in your avatar.
LLB, be careful about getting too new of a box. Make sure you can get it adapted over. "I think" the watercooled 911s have a completely different bellhousing. They are not gonna be any stronger than the older boxes but might create unessecary costs that you could use elsewhere.
Jeff-
VKG Bastage child
Old January 1st 2006, 11:52
Wasn't that a 4WD one? If so, they are a lot longer and need adapting for 2WD use...
Old January 2nd 2006, 00:23
Jeff-
Good thing for me, the water-cooled 911's didn't start till the 996 in 99', so consiquently all of the tranny's from 95' to 98' are all identical apart from the c4 boxes, they have a 9.31 rp, which handles 800 lb ft of torque in a 3100 lb car.
Russell
1974 type 1
98' Audi A4
90' 911 C2
74' beetle
