Old February 27th 2017, 15:05
Originally Posted by effvee View Post
Wow AN-16, your pump gearotor or gears, what size gears. I have a 38mm gear pump however Pauter sells a 26 mm gearotor pump. Then, there's the Autocraft dual savage pump. Walter I envy your steadfastness, $$hit I'm overall the place. Much love in your progress Walter.
Oil pump is my old Thorsten Pieper dry sump pump: 26/38mm. Its on the 5th engine already! First engine with this pump blew up (the old 2,7), so it even consumed some ceramic lifter (remember Schubeck?) particals... but it still gives me plenty pressure
BTW Today my new turbo shipped... I have loads of pre-fun already
Old March 2nd 2017, 14:36
Rule09 Rule09 is offline
No words needed! 👌🏼
Old March 2nd 2017, 14:48
Tnx Roel!
I'am happy as can be!
Old March 2nd 2017, 22:43
Is that an EFR, my son has one on his RB30 drift car, amazing turbo
Old March 3rd 2017, 16:19
Yes indeed it is!
Old March 3rd 2017, 20:27
Beautiful turbo, so you have the turbine speed sensor as well
Old March 4th 2017, 07:29
It has the provision for it, but as I have enough things to figure out and install, using that option is very low on my list atm
Old March 7th 2017, 01:00
What size EFR did you go?
Old March 7th 2017, 19:19
According to the Birdman, exactly the same as your son's?
I also wound some heat wrap at some more critical points (its all the tape I had LOL):
Old March 8th 2017, 00:48
effvee effvee is offline
Hi, possibly re-route that -16 above the exhaust, maybe not between. I can hear it cook.
Old March 8th 2017, 02:40
owdlvr's Avatar
owdlvr owdlvr is offline
love a well-wrapped header...
'71 Type 1 - Rally Project
'75 Type 1 - Family Heirloom
Old March 8th 2017, 18:04
Yeah, it shuold keep temps under control.
Unfortunately, the header design prevents using the bottom plugs, so no twin spark operation in N/A mode anyways..
I had not thought of that tbh..
Made a lousy vid today of the running in, sound was absent due to my crappy phone which had probably noise overload...
https://youtu.be/FFUSaKPvHig
Old March 10th 2017, 06:55
Hey Walter, was that you in the race? If so, it revs nice. I noticed you touched the red line. If so, that G-50 is a real plus.
Since at the present, you are not running dual plugs, how do you protect the threads of the spark plug holes?
Congrats again sir
Old March 10th 2017, 08:17
Congrats again sir
Yeah, on YouTube some other vids of 5 years ago and older probably show up when you check out the above vid
I'll try to make a better vid as I found out why my proper camera stops after 4 seconds video (too low quality SD card...).
I have just turned in the appropiate plugs in the bottom holes. They are not that expensive. easy peasy
Tnx!
Old March 11th 2017, 14:28
It runs now with proper sound ;-)
https://youtu.be/ZrS7QzO2DT8
Currently Active Users Viewing This Thread: 28 (0 members and 28 guests)
