Old May 5th 2010, 06:43
Slowtwitch Slowtwitch is offline
A Possible Linkage Cure?????
I've been working on a linkage setup for some time. I have a type 4 with an original OPP shroud and found the hex bar setup to clumsy and kinda ugly. I don't want to bore you with details and such, so here are some pictures of my solution.
Here's a clip of the intial startup and the linkage in action. I'm using a Megajolt/EDIS setup.
http://www.youtube.com/watch?v=XHiaY4YjHwU
enjoy
pete
Old May 5th 2010, 12:24
I WANT ONE. I would like to buy a couple pairs of pulleys for Dells.
Old May 5th 2010, 14:54
Pablo Pablo is offline
Me too!! Very nice indeed.
Are you making any or was this a one off?
Is it a cable all the way to the pedal or is there some interface between the cables?
Old May 5th 2010, 16:32
Pablo, I'm currently looking at getting parts made, will see how that goes.
As for the cable, yes it goes all the way to the pedal. I made a transition of sorts, that adapts the original accelerator tube to the new cable...works pretty good I also use 2 different type of cables. One type for the accelerator and another type between the carbs.
pete
Old May 5th 2010, 16:34
Hi No_H2O, I left you a pm at shoptalk
pete
Old May 5th 2010, 19:40
petevw's Avatar
petevw petevw is offline
Me too!
'72 super
'65 bus
'52 split
Old May 6th 2010, 05:37
kafer9 kafer9 is offline
Linkage
Hi I would be interested in one of these also.
James
Old May 6th 2010, 16:10
Bug@5speed(US)'s Avatar
Looks similiar to an approach I think JakeR was working on..
Very interesting.. interested also..
A
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
Old May 6th 2010, 16:37
A
I sent Jake an early proto-type, sometime last year.
pete
Old May 6th 2010, 21:31
Lazarus's Avatar
Lazarus Lazarus is offline
i really want one as well. that would probably cure my throttle issues. i only have really a little over half throttle right now with the bell crank i have.
Old May 7th 2010, 11:31
Ouch !!!
pete
Old May 19th 2010, 12:26
Pete,
Have you looked any further into producing a few sets of these yet? Or even just the wheels and brackets. I'm keen to change the setup I have.
Old May 24th 2010, 07:18
Xellex's Avatar
Xellex Xellex is offline
ever since I've first read this topic (and the STF one), it stuck to my mind so badly that I can't get this idea out of my head. I keep thinking about replicating the setup, but it would be so much easier if we could just buy it from you, and not try to reinvent what you've worked on for a few years now..
So, any longer till you get these out on the market?
www.vw1303s.com
