Old January 22nd 2007, 23:37
oasis's Avatar
oasis oasis is offline
Originally Posted by Veedub View Post
I want a 1776,1835 or a 1915, or maybe a 1641cc.I want it to be pretty quick but still be reliable.My budget is maybe 4grand. ... What you guys think it would have for hp?If its a high reving motor that would be awesome IMO, i like cars that rev high
Of these four sizes, the only two that got a reasonably universal thumbs up during my investigation of Type I engines were the 1776 and 1915. I highlighted these portions of the EvilAngel's post below because I think it bears repeating -- especially since you brought up reliability.
BTW, reliability is easy to understand but hard to define. Everyone's definition and threshold will be different.
Originally Posted by EvilAngel View Post
If you want to have reliable pistons, you can only choose between 90.5 and 94. This is because their cylinder wall thickness is the same as stock. ... BTW revving a vw makes it lose useful life, so it loses reliability in that sense.
I am not expert enough to comment on any other details and won't pretend to be.
I will say horsepower and torque are fleeting numbers and can vary within the same hardware selection. Another aspect on horsepower and torque that warrants emphasizing is these numbers will vary with the same exact engine and combo depending on where it is measured.
For example, the original engine in my '71 was as stock as stock can be. The owner's manual lists it as being 60 bhp at 4400 rpm and 81.7 ft-lbs. at 3000 rpm. It was measured on the dyno during November 2005 at 44.5 hp at 4200 rpm and 69.2 ft-lbs. at 2700 rpm.
If one of the experts chime in with a guesstimate or a range with your hypothetical hp, they are more likely to spout a dyno number as the experts I have listened to have access to, have had access to, or own a dyno.
