Old August 30th 2002, 01:42
Michael Ghia's Avatar
Hi,
I looked into it a while back and then other people have done the same since. The 912 flywheel will not bolt onto your crank, it needs machining to fit. I would try the stock Bug flywheel and see if the starter reaches it or not. If not, look into either moving the starter forward or machining some material off the mounting face of the gearbox. Please keep us updated with your progress as this is one which comes up time and time again and no one seems to have done it yet!
MG
