#16
Make sure the ground is good on the lights I had the same problem when i reinstalled my fenders
Vincent W. Strader 64 Type I and 73 1303 going GL top to bottom now if i could just decide wich one. 04 Mitsubishi Lancer plans power 13b Turbo Rotary 300 hp Wheels 18" turbo twists inside Sparco blue racing seats Sparco pedels, wheel, and shifter nob Sparco Rep Andrew @ www.pilotracegear.com Good deals on Sparco stuff
#17
My neighbor came over yesterday (he owns a 65 Beetle) and he found my headlight problem.
It was the relay that plugs into the fusebox for the headlights. He bipassed it with a jump wire and we finally got power to the headlights. Now all I got to do is buy a new relay. In addition to that I also mounted my strut bar & finished wiring my battery up front so that it looks like a factory installation. Here is what I have left to do before Bug Jam: Finish installing rear pop outs Wire up headlights Install wipers Gauges & dash Door panels Carpet Kit Door latches A few small misc things
#18
Sounds like you are going to make it. I've got a couple things to do to my car this weekend(oil leak, change the fan and get new front tires on). I was giong to replace my tach. with a large VDO I have, but I think I will wait untill winter and do a 914 gauge cluster.
