Old December 31st 2003, 19:19
well i could be back to lost then. i have both nuts backed off all the way and the bracket is laying loose. like i said, both adjusters were at the bottom of the welded on bracket anyway. the non-welded bracket is just loose so moving it does nothing obviously. there is too much tension to just move the bolt up and turning it (and i could only get about a 1/4 turn so far) i thought would back it out of the bars and allow them to turn, which is bad since they appear to be under load. your height is adjusted by turning the lage bolt that goes straight into the torsion tube?
i can post some pics in a few.
