Old January 16th 2004, 12:46
T4 IDF manifolds that reverse-mount the carbs
Does anyone make T4 manifolds that mount the carbs (dual) backwards so the idle jets point towards the center of the engine instead of outward ?
Or is it simply just a mater of taking them to a machine shop to reverse the flanges on the manifolds ?
I have a set of IDF replacement 48mm TB's that I want to mount but the injectors are towards the outside of the TB. If I could reverse them, it would make it easier to get to the fuel rail assembly. I'm using a FAT 911 setup so I have the room.
Thoughts ?
