Old February 20th 2004, 23:36
super vw super vw is offline
Originally Posted by 67yellowbug
hi, Great job on the gauges. I have a stock vw speedo and the letters and numbers are getting somewhat faded. How did you paint yours without screwing up? also what kind of paint did you use. How difficult is the job? Thanks for your help
CJ
Thanks!
If the numbers are faded, than im not sure on going about that. The only thing i can think of is to get a new gauge (can be found cheap at swap meets) or a new face.
I did not paint the gauge faces, only the inside (behind the faces) and the rings.
But if you are not going to replace the face and just paint the rings or clean up the insides than what you have to do is get a small flat blade screwdriver, and a medium sized one to.
You have to pry the bezzels from the back till they will slip off the housing... VERY CARFULLY and gently... you MUST take your time and be very cautious not to pry to far, slip, or go to fast. it takes me almost 10-15 minuites to just get one bezzel off. you pry a little at a time as evenly as posible.
For you it sounds that it might be easier to just get a new gauge.
Jonathan
