I'm putting a 2.1 wasserboxer in my Bug, and this has a 228mm flywheel/clutch. The flywheel seems to fit OK and meshes OK with the starter, but the clutch pressure plate fouls the inside of the gearbox casing in a few places, so needs some clearancing to be done to the gearbox. It doesn't seem to need much clearancing though - just a few mm, and only in some spots.
Don't forget to put a bush or needle roller bearing in the centre of the flywheel to support the type 1 input shaft. |
