Old June 6th 2004, 19:19
Mikey 1972GL Mikey 1972GL is offline
That looks great, can't wait to see it finished. Please do keep us posted on the progress. :agree:
Mike
My new user name, Mikey
for some reason, I havn't liked this name since I made it.
Sorry for any problems... Mike
Old June 6th 2004, 19:35
airwerks airwerks is offline
Panlelfantastic, ya smart*ss Your panel is BAD. What kind of power is that GM motor putting out?
By the way, it isnt a real oval so it took alot of the guilt away. I got it as an ex drag car with no rear clip. Dont ever try to weld in a oval dash into a square window car...... royal PITA (top lines up fine, bottom not so good )
Old June 7th 2004, 08:49
Panelfantastic's Avatar
Thanks! You are well on your way also...
My stock Eco puts out 170hp at the crank. Plans call for 350hp next year.
No guilt. It is your car and you can improve it any way you see fit.
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
Old June 12th 2004, 10:56
coxy-ben's Avatar
coxy-ben coxy-ben is offline
19" wheel diameter ??
tyre size ????
Benoît
2FAST4U
Old June 22nd 2004, 03:29
They are 215 35's...... almost too skinny for the rims though.(7.5's)
Old June 25th 2004, 22:30
Axl R's Avatar
Axl R Axl R is offline
Location: Calgary , AB , Canada - Home of the Western Conference Champion Calgary Flames!!!
Cool
Man , that car is going to be SICK when it's done . I am totally hyped on this car . You say its not a true oval - what year is it actually ? Also , What are you planning to put in it to make it go ? Definately keep us up to date on this project . I have to say I like the ovals the best for the bugs . Axl . :agree:
Before you can be Old and Wise , you first have to be Young and Stupid !!!!!
Old June 25th 2004, 22:33
Axl R's Avatar
Where did you get your numbers for your Ecotec motor HP? I work for GM and they don't come with that much ponies stock . Axl .
Old June 25th 2004, 23:16
boygenius's Avatar
I belive Panel is using a marine/off-road program for his computer... No emissions restrictions...
Old June 27th 2004, 00:16
Axl R's Avatar
Not to be rude or anything , but isn't using a different program not considered stock anymore ? But I can go with the 350 HP figure , as GM has designed the Ecotec to handle upwards of 750 HP . The bottom end design came from the latest Corvette engine . Axl .
Old June 28th 2004, 00:46
boygenius's Avatar
Well it very near stock anyway. That is the only mod to the engine to my knowledge but you might want to check with Panel first.
The ecotec engine will fail at around 400 hp. 383 hp if I remember correctly from the testing done on that engine for drag racing research. At 750 hp you need aftermarket crank/rods/pistons/head gaskets/head mods, intake and exhaust.
