Old August 27th 2004, 15:24
judgie's Avatar
judgie judgie is offline
Originally Posted by zen
coming along nicely. what's inside the engine? and hate to say it, but someone put your wheel on the wrong side of the car .
the engine is a bit of a beast.
heads 44x38 welded inlet and exhurst[911 stub pipes]
stock crank and rods but polished and balanced with arp rod bolts
case has been modded for 1/2 inch case bolts and 5th studded
96mm je pistons
2 stage dry sump pump
48 idf's with 40mm chokes
web 86c cam and ceramic followers
kep steel 200mm fly wheel with stage 2 kennedy cover and scat four puck plate
header is home built and has 1"5/8th main pipes 35" long into a 4 into 1 collector then into a 2 1/5 system.
hope for about 170bhp
cheers rob
