Thanks very much for the info..
fastbug.net | FastTrack Dub Club "Straights are the boring bits that link corners together" |
Just a thought, what rims are you running?
rims
I got the discs drilled for a PCD of 5x100 and got a set of FOX 5 alloys with an ET of 35 and the were 17" diameter. The tyres were 235/45/17 and rubbed on all four corners so i would have preferred to get slightly wider wings or smaller rubber but they were fine once you didnt hop the car all over the road.
What kind of gap do you have between the rim and the caliper? Do you think 16" rims might have fitted?
i am sure 16s would fit no problem as there is plenty of clearance it really depends on your et size.
