Old November 14th 2002, 21:00
Danborn's Avatar
Danborn Danborn is offline
I'm running a 2.1 wasserboxer in my oval, and it has a 228mm flywheel/clutch. The flywheel/clutch fouls the inside of the gearbox casing in a few places, so I did a lot clearance in the gearbox. It can be done but the gearbox is paper thin in some places.
And I use a 181/Porsche/T-1 Automatic starter as the stock starter when engaged will foul on flywheel. You could use a T-3/25/Vanagon starter with a 10mm spacer
Jesper
