Old January 29th 2005, 15:03
ok, where to start on this one.
first, you can't always have your cake and eat it to. if you want to adjust height at the drop of a hat, it will cost you. coilovers are the best way to allow that functionality on the super. with a standard you could go adjustable beam.
rear height is easy. just adjust your spring plates on the torsion bars to the height you want. do some searches. plenty of info on how to accomplish that.
front on a super. there are many custom options. none will be one stop or easy. if you want bolt on, Topline Maxx Struts are the best way to go. gives you room for bigger rubber too.
rims in 4x130 are not overly common. they are out there, but few and far between. i would suggest going with 2.0 liter Fuchs if you want to stay with that bolt pattern. it won't get you to 17's, but they look great and are affordable...and bolt on.
and JCW sux. you get what you pay for. and their stuff doesn't cost much. hit the links section on the main page or the links page on volksport.net for a ton of sites with good products.
