hey I have a file I've been working on to help determine this stuff, want to see it? Although it's not finished. I need some input from people who have already finished so I can figure some stuff out, but most of it is good.
This way if you wanted you could simpliy compare the clearance with some one else who says they have good turning. Plus it calculates the turning radius for you.
Rip H. Van Winkle "The Ultimate Sleeper" |
using zen's dimensions he has
11mm less clearance at the arms (compared to stock) 40mm less clearance at the outer fender (compared to stock) but with 2" wider fenders they really tuck in about 10mm. and the turning radius increases 6.5% 18 ft to about 19.3ft PLEASE NOTE THAT THESE CALCULATIONS ARE NOT COMPLETELY ACCURATE .
Rip H. Van Winkle "The Ultimate Sleeper" Last edited by rip; May 3rd 2005 at 14:39. |
using Dasdubber's dimensions before the narrow and spacers he has
62mm less clearance at the arms (compared to stock) 2mm less clearance at the outer fender (compared to stock) and the turning radius increases 37.3% 18 ft to about 28.7ft After 40mm less clearance at the arms (compared to stock) 16mm more tuck at the outer fender (compared to stock) and the turning radius increases 24.9% 18 ft to about 23.9ft PLEASE NOTE THAT THESE CALCULATIONS ARE NOT COMPLETELY ACCURATE .
but with out some sort of indication about how much can one narrow the beam without inner fender rub, the turning circle is currently based on the spacers.
with more input of how far a person can narrow with out clearance issuses I could factor that in and then I could tell you based on the full setup your clearances, turning circle, and rub factor.
I've fitted many rims to late model Std. Beetles, from stock height to ~8" lower than stock...the practical limit up front with stock fenders is 5.5" - in most cases you can squeeze 6" in there and still retain an almost stock turning circle though.
With an entirely stock width BJ front end you don't want to exceed much past ~125mm backspace and/or ~45mm frontspace. If you want a 7" wheel under the stock fender @ 2.5" lower than stock and your front trackwidth is 2" greater than stock you're looking for a wheel with an offset of ~70mm or greater - There's one style of OE Porsche wheel that I know of that comes close...16x7 ET65 - but they're not exactly stylish by most peoples standards. It'll be one hell of a challenge to get them under stock fenders with a stock width beam, and even if you narrow the beam or find a wheel with the correct offset your turning radius will still suffer too much for my taste. So I'll tell you what I tell nearly everyone, get wider fenders. As far as the back goes...most people go with 7" ET40 for stock IRS/fenders; if your rear track is also 2" wider than stock than you're basically right at 7" ET65. |
