  #23
Old November 15th 2005, 02:12
EvilOval EvilOval is offline
I got my back issue of Ultra VW today (I'm glad I got a 1yr sub....hot vw's should take some notes). After going thru the article's installation its sure alot easier than the known 901 install. Just some notes.....you will have to remove the front tranny mount from the pan (not a big deal...but a slight bummer), a hole is required for the shift linkage to go thru (same thing you would do the standard way) and you still have to clearance some areas of the frame horns to fit the tranny (a few more than the standard way). The extras are to fit the relocated clutch tube and the cable guide bracket. Some welding is required but not that big of a deal, you will have to move the clutch tube in the pan to clear the tranny (small tack weld).
Also some notes to think of: It would be easier to do this conversion with the body/pan separated from each other for obvious reasons. I won't have this luxury due to space limitations....so it will be interesting to say the least. Also, due to the location of the tranny's front mount you will have to remove the trailing arms from the IRS pivots to install the washers/bolts and spacers (good time to install new bushings since your there).
72' 1302 Vert GL (T4 powered money pit)
69' Ghia GL (T1 turbo powered and in pieces)
