by the way, i'm ordering the 993 rear suspension assembly on Mon. the 28th and i got my ej20tt a month ago. The biggest thing i'm saving up for so i can really start fabbing up some shizzle is the 6 speed g50. Too bad its $3500 then 1100 for a lsd, with 500 hp and 400 lb/ft of torque, i don't want to worry about 1 wheel burnouts. Good luck with your project, its looking great!
1974 type 1 Turbo 6 piston brakes at all corners ![]() Project is taking all my money and it's all Germanlook.com's fault! 98' Audi A4 93' T-Bird (oh yeah!) 90' 911 C2 74' beetle |
The steering is now complete. I'll get pictures soon. I had to enlarge the hole for the steering shaft at the front bulkhead by about double towards the midline to accomodate the steering shaft angle dictated by the rack location.
A friend of mine machined a spacer for the end of the steering column to resist in/out sliding of the steering shaft. It inserts into the end of the steering column and rides on the edge of the Flaming River U-joint. It should work out really well, but it uses the stock 1960 steering wheel. It's very "sleeper" but I'm afraid I'm going to have to do it all over again with something I can use the Porsche 996 Tiptronic steering wheel on. Jason
Tiptronic? You don't have an auto, do you? Just want the buttons for something else?
No current VW projects 54 Chevy wagon LS2 AWD 56 Chevy Panel "Lost Cause" VKG Bastage child |
I figured I could use one of them for the volume control, and the other to shoot laserbeams!!! Seriously though, 2 possiblities, full track/volume control, or they have this sequential shifter that comes out of racing that could be used to shift. I'm thinking those buttons will be used for volume control for a LONG time before that tranny will get into this car though!
Sequential... yummmm
!Jeff-
+44 (0)7812 167547 martinandsonjaATf2sDOTcom |
I knew I should have bid on it
Rock and roll, the rear suspension is here, so is my motor (to bad i'm only gonna use the heads off of it), and i'm still looking for a good deal on a g50.
I should add it was a '95 year box and the porsche forums i looked up suggested avoiding these early year boxes.....
Darren, sweet looking panel in your avatar.
LLB, be careful about getting too new of a box. Make sure you can get it adapted over. "I think" the watercooled 911s have a completely different bellhousing. They are not gonna be any stronger than the older boxes but might create unessecary costs that you could use elsewhere. Jeff-
Russell
Wasn't sure when the waterpumpers started, don't they all have basically the same bolt pattern until then??
Jeff-
http://www.ricola.co.uk |
