  #20
Old January 22nd 2006, 21:10
nbturbo's Avatar
nbturbo nbturbo is offline
Got the handbrake finished-had to make some extension tubes to lengthen the original tubes in the pan-I had to reposition these when I modified the pan for the auto,and didn't know how long they would need to be-I was too short by 85mm-all works OK now.Finally finished the auto dip stick tube.I took ages to decide where to actually make it fit-decided to bring it into the engine bay.Had to make it 100mm longer to get it in and at the correct angle.Shortened a dipstick from an auto Kombi and scribed new level marks.Have made the dipstick an airtight fit in the tube to prevent any fluid being blown into the engine bay-will weld an 8mm tube high up on the outer tube and fit a filter and drain pipe to vent any fluid out behind the LH back wheel.Now it's back on the ground,I think I will lift the back one spline,then align the rear wheels.I have all the VW tools to line up the back wheels.
