#31
That should take care of it!!! I'm really impressed that you're able to run your shifter cables through the shifter tunnel. I have to run mine outside due to the position. Your coolant lines run under the motor and up the back?
#32
![]() IMG]http://i6.tinypic.com/14mct8m.jpg[/IMG] ![]()
#33
yearh be nice i can understand what u mean an say, i like things to be right plus it be classed as a kit car (q plate then tests and inspections by vosa/dvla )so work as stopped (its time to dismantal the idea nice while it lasted thanks all for your coments
#34
nice while it ladted (got voza poeple coming 2moz just to see what they say?lucky only stands me at 80quid (thank god i ant got 1000s sat in it,ill let you know the outcome
#36
a few pics here (its now a monster 340bhp remaped ecu,bigger turbo, and thought id put a dumpvalve on it too ![]() remaped ecu(inside) ![]() nice new big turbo Last edited by adaptorman; June 30th 2006 at 21:13. |
#37
![]() rad fitted and piped up ![]()
#38
did my own drill and tapped discs
#39
![]() header tank and cooling system sorted front end all welded up ![]() shorternd my driveshaft ![]() rear wing weled up
#40
![]() ![]() didnt want to cut it but had to be done (ok 4 a first attempt with angle grinder lol
#41
and a video of it runing (hope you like it)couldnt rev it higher as theres old biddis nextdoor and wasnt water in the lump back then lol
http://video.tinypic.com/player.php?v=141nnk4 |
#42
I'm sure you'll sort a way of getting cool air to the rad without cutting the bonnet like that, I guess it's OK to debug it...
So, when's the first drive? Rich
http://www.ricola.co.uk |
#43
![]() ![]() 90percent of welding done,a new type assembly is next ,as the old aircool idea is no good?
#45
few more home made jobs here
